Originally Posted by
ligito
I have a couple 12 volt Harbor Freight winches that I can use.
A buddy had mentioned the method of running the cable underneath, through a couple of pulleys and mounting the winch in the front.
I just wondered if this method was sound, as my buddy has Alzheimer's and I'm not too sure about his memory.
I also don't know of a good source for conveyor belting, or if pond liner would be substantial enough.
I think your buddy's idea is a pretty good one. I like it better then the tailgate device they make. That tailgate pivots on two points that I don't think are all that strong as they didn't need to be for the intended purpose of simply raising and lowering the tailgate. Besides that, unless your truck is nearly new, those pivot points are likely pretty well rusted through.
My solution these days is to hire someone when I can! It takes me longer to recouperate from the muscle strains then it did years ago
$20.00 to a neighborhood kid should get that gravel anywhere you want it !!
