Results 1 to 10 of 10
Thread: Is milling a morse 3 taper difficult?
    tony ennis Guest
    Default Is milling a morse 3 taper difficult?
    I'm looking at ebay and I see a 7" long tailstock ram for a common-as-dirt lathe selling for $60. It has a morse 3 taper (female) on one end and a left-handed acme thread on the other.
    I could see this if the morse taper is hard to mill. Is it?
    On the Oil Coast
    It's not hard,but it does take time and if your lucky a couple MT3 reamers.From having made a couple tailstock barrels I say $60 is more than fair.Last one I made was a replacement for a lost one,2-1/4" od chrome rod,reamed the taper and bored the back for a lh acme bronze nut.It took me nearly 9 hours to gen that one out.
    Jun 2006
    Austin, Texas
    But to put that in perspective Weird, you probably made a much nicer tailstock ram than came on your lathe: hard chromed, with a bronze acme nut.
    My Clausing 5914, which is considered a low-end toolroom lathe, has an unhardened cast iron ram with an integral, non-adjustable acme nut.
    I bought my lathe from a VoEd school, so it had very low mileage, but you know a cast iron sleeve is going to wear, as well as the integral acme nut.
    IOWOLF Guest
    Hard to mill? Yes ,It would be much easier to turn on a lathe.
    Wolfie !Wolfie! naughty! naughty! Alistair
    IOWOLF Guest
    Hell, I thought I was being nice,Scottie.
    I could have said....Oh, nevermind.
    tony ennis Guest
    nice ........
    Taylorsville Ky
    Personally I would like to see someone MILL a female 3MT taper. That may be very interesting and educational.
    Nov 2003
    Vancouver, WA
    Lathe would be easier. But could be bored in mill and shrink or loctite in a #3 morse taper socket, comes with tang socket and hardened.
    http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=32176430
    Aug 2005
    shreveport La
    Smile
    Stand vertical in 8 inch super spacer . Drill center hole step drill a few sizes and ream to size. A mill is just a lathe stood on end.
