i am rebuiding a transfer case that was cracked when front drive shaft broke. I have the case welded and am putting it back together. The shifting forks have plastic guids on them that are worn out or broken. I was thinking of brazing on to the forks and then machining them to fit. The brazing should last longer than the plastic but still be softer than steal.
Do any of you see a problem with this or have better idea?
