Results 1 to 6 of 6
Thread: Drill Pad
    Hesperia, CA
    Default Drill Pad
    What is a "drill pad?" I see them on E-Bay from time to time. Usually with a MT on one end and a flat disc on the other. Just curious. Maybe I need one.
    SP
    Feb 2006
    Harwich,Essex,UK
    Drill pad is used to do a bit of reverse drilling in that the drill bit goes in the chuck end usually a morse taper drill into the head stock. The bit to be drilled is fixed to the drill pad in the tail stock which is then pushed against the drill.
    Really only used these days if you only have the one machine the lathe.
    Most model engineers would only have the lathe hence all the attachments and fittings for the Myford lathe.
    If you have a drilling machine the pads are not much use.
    Peter
    Hesperia, CA
    Thanx again Peter. I guess I don't need a drill pad after all.
    SP
    California (mid state)
    Talking spider use
    Quote Originally Posted by pntrbl
    SP
    Hello!! PNTRBL A use for a drill pad is to make into spider for large tubes
    c'bore a .625 hole by .375 or what ever you want then tap a 3/8 or 1/2 thread
    make a holder for whatever bearing you have in your bearing box ,a flange on
    back of i. d. bushing might be a good idea , then make a o. d. sleave for bear-
    ing with flange, have 1 1/2 or 2" of radius bigger than bearing , use 3 jaw
    chuck & 1-2-3 block to scribe line on o. d. of sleave,tap 1/4 or 3/8 for spider
    arms , use whatever lg. of bolt or threadall you have , the c'bore is so you
    can use for other uses!
    Larry
    Default Drill pads....
    Drill pads are the kind of tool that you usually find in a box of stuff that you get with a used lathe that had been owned by an old-school model engineer.
    I've never used one in over 20 years of machining either at home or as a job.
    So I'd say relegate them to other uses as mentioned, or let them stay as pictures in How to Run a Lathe or the Atlas book.
    Rick
    Oct 2007
    Northeastern Iowa
    For What Itís Worth:
    I have a drill pad with a ĎVí on the face. I use it all the time to cross-drill round stock of any sort. To me, itís very convenient as the setup is always centered up, you just need to chuck up your drill, seat your pad in the tailstock, slide your tailstock close, then use your left hand to slide the workpiece in the groove to locate your hole, your right turns the tailstock handle. Perhaps I like it because it puts the job where you can easily see things for quick work. Just be careful when the drill breaks through so it doesnít try and pull the workpiece away from the ĎVí and start it spinning with the drill.
    Iíve got a Bridgeport and drill press, but if I just need a quick cross-hole drilled in something Iíll usually use this method.
    Chandler
