Has anyone ever given thought to designing a small taper turning attachment for one of the small 7 x 12 mini-lathes? I realize you'd need to disconnect the cross slide screw but it just don't seem like it'd be a big deal. I figure a cam follower on a bracket attached to the disconnected cross slide picking up a slot milled into an angle adjustable bracket mounted to the back of the bed. Opinions, ideas, comments?
