Results 1 to 5 of 5
Thread: Horizontal Mill ID Help
    Jul 2006
    Arroyo Grande, CA
    Default Horizontal Mill ID Help
    I lucked out when a neighbor moved out of state and didn't want to take his small mill - he gave it to me. I've done some searching and have not been able to find any info on it or any reference to Machine World (Taiwan) or Tai You. It's a horizontal mill with a vertical head that bolts over the horizontal spindle (as shown in the photos). The horizontal spindle is a NMTB30 and the vertical is R8
    Here are links to some photos:
    http://s274.photobucket.com/albums/j...30031Large.jpg
    http://s274.photobucket.com/albums/j...30023Large.jpg
    http://s274.photobucket.com/albums/j...30024Large.jpg
    http://s274.photobucket.com/albums/j...30025Large.jpg
    http://s274.photobucket.com/albums/j...30030Large.jpg
    Has anyone ever seen one of these or have any idea where I should go for info? Any thoughts on what oil to use in it? Any help is greatly appreciated.
    Glenn
    Oct 2004
    Prestatyn, North-Wales
    only thing near it i could find
    was a company called Taiyo-Seiki who make lathes and milling machines
    all the best.markj
    IOWOLF Guest
    Nope , Cute li'l thing though.
    Jun 2002
    Ashland City, TN
    I'd write to the manufacturer. The mailing address is on the ID plate.
    On the Oil Coast,USA
    No help on the maker either,but for oil I would drain some out and see what it smells like first.If little or no oder then it's probably spindle oil,if it out right stinks then probably gear oil.
    As to viscosity look up the SUS test in Machinery's handbook and you can home in on it.Pulling a cover or two might yield more info and might allow you to determine if it uses and oil pump or splash lube also.
    Good looking stout little mill though,can't beat the price either!
