Results 1 to 10 of 16
Thread: homemade table saw rip fence
    Default homemade table saw rip fence
    I have a 10" craftsman table saw and would like to make a rip fence that is accurate and dependable. If you can refer me to a source of plans or have other recommendations--please advise. Thanks Paul
    Jan 2008
    Baton Rouge, LA
    Check out Fine Woodworking's Shop Accessories You Can Build. There is an article about making a Biesemeyer style fence. It should give you some ideas, but the fence is sort of crude.
    Kurt
    Nov 1999
    SE OZ
    Default Fence etc.
    Thanks Kurt.
    I have an interest in that as well.
    I "Googled" "Fine Woodworking" and got the following links:
    http://www.google.com.au/search?hl=e...G=Search&meta=
    http://www.taunton.com/finewoodworking/
    http://www.taunton.com/finewoodworki...oodWorking.com
    Jan 2008
    Baton Rouge, LA
    Jul 2003
    Temple, Tx
    I don't have a specific link, but I do have several suggestions. First, it is very useful to have a fence that sticks out both behind and in front of the saw table. This will help you control large panels before they reach the blade and as they exit the blade. Secondly, I find it useful to be able to lock down the back of the fence as well as the front. This is helpful if you are using the fence with a hold down that puts downward force on the work. The yellow wheel type work hold downs are a good example, but many other jigs apply downward force on the work. My own saw fence is a type that is no longer made (Paralock), but it has a drawing table type wire setup that keeps the fence parallel to the blade as you move it. I have compared it to a Biesemeyer with a dial indicator and it is much better at keeping the blade parallel. Part of the reason is that the rear of the fence locks as well as the front.
    Jul 2007
    Default Table Saw Fence
    Fine Woodworking ran an article on a fence design by a retired electrical engineer, (electrician?) from Victoria, BC. The design relied upon Unistrut for the fence rails and rectangular tubing for the fence itself. It was "tarted up" by using anodized aluminum extrusions an is(was) marketed as an aftermarket unit by Busy Bee tools. I have one on my Craftex cabinet saw, and I find that it works very well, maintains parallelism, quick to set and accepts accesories. You could sure build it from the article for a LOT less than the commercial unit, and it would serve very well on a Craftsman saw.
    Jul 2003
    Duffy
    I built the unistrut version from FWW and used it for a long time and it works very well. Mine was on a 10 inch Craftsman. There was another version published in FWW that more resembled the Biesmeyer and it looks very simple to build.
    I made my own and overhead collection system even had the biesemyer name made up Alistair
    Feb 2006
    Smile
    Check out these links for some tamle saw accessories.
    http://home.comcast.net/~jaswensen/
    http://members.aol.com/Alamaral/WoodShop.html
    When I get Time... I'll...
