Results 1 to 4 of 4
Thread: Aluminum Rod - 5 MM?
    Aug 2003
    Default Aluminum Rod - 5 MM?
    Might anyone be able to recommend a source for small quantities of 5 mm aluminum rod? I'm not that concerned about the alloy - just has to be bendable and 5 mm.
    Thanks,
    Tom
    Feb 2008
    Ashcroft, British Columbia
    if you can live with 4.76mm you can find it on ebay here...Item#110229867251
    Ernie (VE7ERN)
    northwest wisconsin
    would stick welding rod be a source ? knock the flux off..
    Lexington, Ohio
    Tom,
    Available here but could be more then you need/want.
    http://metricmetal.com/products/round.htm
    Ken
