I want to replace the valve guides in my IHC 113 overhead valve engine . I think it requires the head to be preheated to 350 deg F. Then the guides can be press or pulled out . If have any tips on this task I would to here about them before I proceed. I Tapped on them with a brass rod and they didn't move so I assume heat and a arbor press is the method .
