Results 1 to 10 of 33
Thread: Do I need a tang or a drawbar?
    Mar 2004
    SE, Michigan
    Default Do I need a tang or a drawbar?
    Mini Mill X1, MT2 arbor taper.
    I can get a tang endmill holder tomorrow with the rest of my J&L order, ordering one with a drawbar thread will take a bit of time because I have to get it from littlemachineshop.
    Just wondering if I actually need a drawbar for basic milling operations, or if I can get by with just the tang.
    tattoomike68 Guest
    Yes, do it...
    Mar 2004
    SE, Michigan
    thanks for the advice...
    do what?
    Taylorsville Ky
    For using an endmill you will need a drawbar holder. The side load will dislodge the taper
    Mar 2004
    SE, Michigan
    ok...then this begs the question.
    why do they make endmill holders with tangs??
    Maine
    You need a drawbar. I have no idea how a tanged end mill can possibly work, as all my experience says the cutting forces will pull the end mill out of its socket.
    Aug 2004
    Traverse City, Michigan
    The draw bar is the way to go. However, you might be able to get by with the tang if you are milling plastic or maybe wood. Gary P. Hansen
    Taylorsville Ky
    Snowman, that is a valid question. I don't know why they do that but I would only use the tang type for drilling.
    I tried using a MT holder in my lathe once and it came out, broke the mill cutter and screwed up my project. It won't happen again and that was around 1968 when I got that lathe and didn't know any better. It had a threaded hole but I didn't think I needed a drawbar.
    rustamd Guest
    i was always teached that tang type were used for lathe to hold like center drills, drill bits, etc
    Beaverton, OR
    Does the tanged endmill holder have a slot in the middle of the taper. Some tapers are designed to be held in with a wedge.
