Results 1 to 10 of 21
Thread: OK whats with these diamond tool bits?
    Feb 2008
    Prince Edward Island Canada
    Default OK whats with these diamond tool bits?
    I have been reading about tangential tool holders like these ones:
    http://www.gadgetbuilder.com/ToolHolders.html#Tangent
    http://www.eccentricengineering.com.au/
    From what I can figure it is neccessary for the tool bit to have a diamond shape to it so that it can have both front relief and side relief. But I have never seen a diamond shaped tool bit. The second link above says "ALL from a standard square HSS toolbit ".
    What am I missing here? Do diamond shaped tool bits really exist? Do people make their own?
    Feb 2006
    Harwich,Essex,UK
    I dont think they are diamond shaped just a normal a square hss tool bar held so that only 1 corner is cutting.
    Peter
    Forgot to say that the tool bit is ground at an angle so the end is diamond shaped.
    Yes, if you slice a square toolbit at an angle to the length, and from corner to corner diagonally, the resulting flat surface will look like a diamond shape. This is the face presented to the cut, or the face you see looking straight down from the top.
    Feb 2008
    Funny, I thought about this off and on over the past year and could not figure it out. Then about a minute after I hit the POST button it all made sense to me.
    Feb 2004
    well, that will present a diamond, but on an obtuse corner. so it kinda sucks for facing or turning.
    Mar 2008
    Kent, U.K.
    Hi.
    Great forum you have here.
    I'm thinking of making one of these for external-thread cutting. Does anyone know off-hand the angle that the square hss tool must be cut at to produce a 60-degree cutting angle on the top face for cutting metric threads? If I have this angle I can prduce a jig to make & re-sharpen the cutting tool on my bench grinder.
    Welcome Peter,
    I'm at a loss as to how a sq tangential tool can be used to cut threads. Remember the cutting edge of a tool must lie on a plane that passes through the lathes axis - in other words the whole length of the cutting edge must be at centre height. Since a threading tool has two cutting edges, it would be difficult to make a threading tool without a flat top, ergo what advantage would there be in grinding the sides and the top of a tangential tool vs just the sides of a horizontal tool bit?
    Mar 2008
    Kent, U.K.
    Hi McGyver, than you for the welcome.
    I've read several long threads today and I can't find the reference to it to re-read it, but I'm sure I read that the tangential tool can be used for thread-cutting. I figured, that if a square tool was held so that one corner was touching the work, and the holder held that tool at somewhere like a 45 degree rake with the tool ground so that the cutting face is on a horizontal plane, then the acute angle of the diamond presented to the workpiece would be somewhere around the 60-degrees needed for thread cutting. Easier to draw than explain I guess. Kind of like the photo below but with the tool rotated in the holder 45 degrees.
    If this would be possible I could easily make a jig to sharpen my hss bits to cut threads without having the pain of trying to achieve the correct angle by hand.
    Jun 2006
    Austin, Texas
    I've asked this question before, but I've never gotten a concrete answer: does the diamond toolholder cut easier/nicer, or is the main advantage that it's easier to sharpen the bit?
    The diamond toolholders are often shown in the old turn-of-the-century machinery books like Robert Smith's Advanced Machine Work. But those books don't mention any specific advantage to the diamond tool either -- they just show the tool, and how to sharpen them.
    In fact, the 5th Ed of Advanced Machine Work shows grinding a diamond tool for a normal Armstrong 1S (straight) toolholder: since the Armstrong is inclined already, you just grind a little more back-rake into the insert, and you have the same tangential tool contact.
    Feb 2008
    Part of the reason I was confused about this is I thought that a tangential tool would have some part of the tool tangent to the work piece - but it really doesn't.
