Results 1 to 10 of 12
Thread: What is KEA108?
    Feb 2006
    York, SC
    Default What is KEA108?
    Was described as a flavor of free machining drill rod (silver steel).
    Oregon
    A 60's license plate number?
    Feb 2006
    York, SC
    Just so it will NOT be confused with license plate numbers et al, the designation came from the book "Clockmaking for the Home Shop Machinist". Lautard footnoted that it wasn't available in the US. I was looking for some comparable
    metal as I am not particularly fond of machining drill rod.
    Palmer Alaska
    Default These guys use it in valve seats
    Must be a British name for a form of alloy steel.
    http://www.bisvalves.co.uk/products/...alve-hp-rl75c/
    http://www.bisvalves.co.uk/contacts/
    not much web search info....
    for what its worth... I'm out here in Italy and one of the
    tool steel "staples" is K100. Not really sure what the US
    equivalent is but from experience it seems to be close to
    an O1.
    did some superficial searching and found this:
    http://www.heat.com.au/docs/Common%20steels.pdf
    it makes references to a "KEA180" -- could that be it?
    -Tony
    Castlegar BC Canada
    Default Ke108
    According to Google it's a stainless steel used in ear rings, go figure. I've never heard of it before. Peter
    The difficult done right away. the impossible takes a little time.
    KEA108 is a British "silver steel" (drill rod) which contained selenium to make it free cutting. I was great stuff for cutting clock pinions. It is no longer made. I have a small stock of it, which I use only when necessary. It is very easy to machine.
    IOWOLF Guest
    I thought Selenium was used to get rid of aliens.
    Obscure movie reference.
    Aug 2005
    Atlanta Ga USA
    It seems to me that O-6 would be a very good replacement alloy. It does machine rather well, though I have never been exposed to KEA108.
    Jan 2006
    Suffolk, England
    Quote Originally Posted by IOWOLF
    So maybe using "Head & Shoulders" as a cutting fluid would make drill rod easier to machine?
    Peter
