Results 1 to 10 of 25
Thread: OT...Repairing old motorcycle intake manifold boots???
    Dec 2003
    Default OT...Repairing old motorcycle intake manifold boots???
    Hey guys! The rubber intake boots on some of these old motorcycles... they crack after time and need to be replaced.
    However, a lot of them are not available anymore.
    I just rebuilt a KX80 for my helpers boy to race and the damm intake cracked when we where putting the carb on.
    I've tried every source but cannot find one.
    Anyone know if there is a magic Goo out there that'd fix this?
    Thanks!
    Russ
    Nov 2004
    I have fabbed adapters out of aluminum with a chunk of goodyear green stripe hose to connect the carb to the adapter, trick is to figure out how to make the transition into the reed cage ....every one is a little different...Good luck Shawn
    Feb 2007
    Sikaflex will give a flexible repair which holds up, I once patched a nail hole in a tire one Saturday night for a 200 mile round trip on the Sunday, the tire survived and continued hold air until the tread was gone,
    Regards,
    Nick
    Torker, stay away from anything to do with radiator type hose as it will swell as soon as gas hits it, there is some industrial type hose that is rated for oils and would most prob. be OK, If the boots are offset in diameter you may have to make adapters and that will suck, it will also slightly upset flow if not tapered --- Those damn things always weather check...
    Mar 2008
    Portland OR
    Detroit 'burbs
    Quote Originally Posted by torker
    Thanks! Russ
    How about using the old one as a pattern to mold a new one? Here's a few links:
    http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
    http://www.smooth-on.com/
    http://www.polytek.com/
    Dec 2003
    Shawn.. this one has a real ugly angle into the head.. I thought about tryingto machine one from alu.
    Nick.. where do you get Sikaflex?
    Boomer.. yup, I already know about the gas swelling up rad hose. I see a lot of that done here when I take in old bikes.
    Scott and Bob... I was wondering about casting new ones. I'm actually suprised that the aftermarket hasn't covered this.
    The snowmobile aftermarket is all over this. You can get intake boots for almost any old sled.
    I really need a quick fix as he has a race over in Alberta this weekend.
    Russ
    Feb 2007
    Sikaflex is the stuff modern car windscreens are bonded in with, Polyeurethane Adhesive Sealant is the generic name for the product, it comes in a variety of curing speeds. It's also used to stick side panels on busses, roofs on hightop conversion vans, I used it to stick GRP wings on a car once, provided you clean the surfaces to be bonded it doesn't come off!
    If you ask windscreen replacement shops they will often sell you a tube, sometimes they'll give you half a tube if it's the end of the day as it doesn't store well once open,
    Regards,
    Nick
    Sikaflex sounds like it might be a better fix but I've had pretty good luck repairing cracked motorcycle intake manifold boots with "Shoe Goo" or "Plumbers Goop", "Mechanics Goop" or any of the similarly named products which are all the same thing. It's very useful stuff for all kinds of repairs and I carry a tube during bike trips.
    Oct 2007
    skiatook oklahoma
    torker what about building a plate that is thick enough to machine then hand port the proper radius,and attach a four stroke type intake?we use this kind on yamaha banshee's.just a thought.
