I'm building a machine from a plan and it states numerous times that a hole should be drilled and then reamed out. It seems to be for two different reasons. The first is to make a snug fit for bolts. For example, a 1/4" bolt has a 1/4" hole drilled, and then a .251 hole reamed out. Another example is an injection rod having it's hole reamed out to .501, when the rod is 1/2".
A) I'm having trouble finding chucking reamers in these specific sizes.
B) The one's I've found haven't been cheap.
C) I find it hard to believe that each hole, to a thousandth of an inch, needs a seperate reamer.
Can a boring head do it? Can an adjustable reamer work (Harbor Freight has them, are they good? Do they work? Are they worth the money?)
As always, any comments appreciated. Thanks,
B2
