I purchased a step pulley Bridgeport over a year ago and have been using it for various small projects. The auto crossfeed does not work and now I find myself needing it.
I've attached pics of the crossfeed motor and would appreciate any feedback on getting it up and running.
In the last pic I've attached, you can see the underside of the mechanism with the cover removed.
The motor does work, but there are missing parts between the motor output shaft and the input shaft that drives the leadscrew.
I would appreciate any sources for the missing parts or other helpful comments?
thanks,
Mark
http://www.carringtonfamily.com/temp/mill1
http://www.carringtonfamily.com/temp/mill2
http://www.carringtonfamily.com/temp/mill3
http://www.carringtonfamily.com/temp/mill4
