Results 1 to 8 of 8
Thread: Tire Truing on a Lathe
    Chardon, Ohio , USA
    Default Tire Truing on a Lathe
    I've seen a y tude demo of a tire that had a flat spot on it that was turn true after a bit of work . I would to know if anyone has done a 23x 10.5 -12 on a lathe to true it up ?
    Nov 2002
    Central Pa.
    Default Tire turning
    Going to need a big lathe for that. I HAVE turned rubber. Drilling is a b*$ch but turning with tool is not bad.
    mark61
    Aug 2003
    Default Tie
    The best way to remove the flat spot is to grind the tire. A good tire shop should be equipped to perform that service.
    JRW
    I see probs with turning a tire, for one bit sharpness is of the utmost importance, for two - all kinds of little rocks hanging out in the little sipes and grooves ready to make point one a real problem...
    Oroville, WA
    Somewhere around here I have pictures of a buddy using my belt sander on his Harley softtail's rear tire. It was too wide, for some reason, and the belt sander and the spinning wheel still on the bike made short work of the problem. It also made my garage stink, but I was on the way to Sturgis and didn't really care
    Deep in the Heart of Texas!
    Don't need a lathe. Spin it on wheel balancer. My portable will handle tires up to something like 55" in diameter or 300 pounds. Fixed mounted balancers can go larger in some cases. The problem with fixed mount type is overriding the spin cycle to keep it going. You have to crank my portable.
    Vancouver's Island
    An angle grinder with a coarse disk works too. I just did the same thing to make some clearance on my E-bike.
    Apr 2006
    Northwest Missouri USA
    Big Lathe, Spin balancer, Tire shop? Where's your sense of adventure. If you got the wheel, the tire and the problem you must have the vehicle it that spins it. A bumper jack and a brick on the gas, what else you need. Oltimers around here used to hull walnuts throwing them under a spinning tire like that.
