Results 1 to 10 of 18
Thread: Cleaning out gummed up 2 stroke carburetors?
    Dec 2005
    Default Cleaning out gummed up 2 stroke carburetors?
    Anybody got a fix for the white crap that gums up jets and internals in a 2 stroke carb?
    I tried acetone, no fix. Don't have a ultrasonic cleaner anymore.
    Excuse me, I farted.
    Jan 2006
    Northern Neck Virginia
    DYKEM solvent, for removing layout blue.
    Pour in the carb, swish around for a minute and pour back out; stuff works like magic.
    Jan 2007
    Northeast Texas
    Brake cleaner, non-chlorinated.
    Wear rubber gloves and do it outside.
    Default Mek
    If it were me, I'd try MEK (methyl ethyl ketone) sold in Lowes or elsewhere. A gallon goes a long way. WEAR nitrile gloves and don't breath the fumes. But FWIW, MEK was the main component of Gumout carb cleaner years ago before they changed the formulation. It worked very well but is one nasty chemical to get into your system so do the right thing
    "To invent you need a good imagination and a pile of junk" Thomas Edison
    Better to have tools you don't need than to need tools you don't have
    73's KB3BFR
    Dec 2003
    Streamwood, Illinois
    I've had very good luck using denatured alcohol for cleaning out fuel tanks with *very* old gas in it. It takes a while but it will strip out all of the old varnish that has accumulated. It hasn't effected the plastic floats in the carbs either, other than to clean them. Can't say what it will do to the carb diaphrams though.
    Tom
    Be careful what you wish for, you might just get it!
    Chipslinger Guest
    Av. Gas, That's Aviation Fuel to the Vertically Challenged.
    Apr 2006
    Northwest Missouri USA
    Wait-A-Minute, Harleys aint 2-strokes. Waddaya workin' on a Wizzer?
    Chipslinger Guest
    I dont thik wizzers were either.
    Edit to Add, Some Harleys were in the 70'S.
    Jan 2006
    Suffolk, England
    David, brake cleaner is very good for cleaning out the muck and corrosion.
    However, remove any rubber seals, diaphragms and plastic parts before you use it, as the brake cleaner will kill these.
    Peter
    Dec 2005
    Default Dead 2 stroke harley
    GKman: now, ya gotta know all my life, thou I love them is not motorcycles.
    Currently all harleys are running here. I do have a dead ninja 1000, and a malfunctioning weedeater. I've been gave a old Armuchie? harley.. It has a lot more wrong than the carburetor thou.
