ATTENTION GREG PARENT
Greg,
I had a funny feeling about tantalum so looked up the MSDS. WARNING! Extremely flammable. May ignite spontaneously on exposure to air. Dust/air mixtures may ignite or explode.
DO NOT try machining this metal.
Negligible fire hazard in bulk form. Dust/air mixtures may ignite or explode. May ignite if exposed to shock, friction or heating. Avoid friction and static electricity.
Thermal decomposition may release toxic and/or hazardous gases.
[added]
Health Haz Acute And Chronic: MAY BE HARMFUL BY INHALATION, INGESTION/SKIN
ABSORPTION. CAUSES EYE & SKIN IRRITATION. MATERIAL IS IRRITATING TO MUCOUS
MEMBRANES & UPPER RESPIRATORY TRACT.
[This message has been edited by Evan (edited 07-09-2003).]
Hello Evan,
Thanks for the heads up. I know what I am going to do with the stuff now...bring it to the toxic waste dump across town.
Thanks again.
Greg
Rather than the dump, call a scrap dealer. Ta
scrap is worth $ even if it only few lbs.
Thank you Stan, Another good idea. Waste not, want not.
Just one question...........
Tantalum capacitors (solid tantalum, not wet type) are very common in electronic equipment.
They are known for turning into short circuits, BUT, in the process I have NEVER seen one burn, or offer to. I HAVE seen them get rather hot.
If the stuff is that explosively flammable, it seems that one might see the capacitors burn.
Are you sure the MSDS is not being over-conservative?
Did you look at the MSDS for aluminum?
Did you check one out for distilled or de-ionized water?
(BTW, the MSDS I saw for lab-grade distilled/deionized water has a number of dire cautions, including that the container should not be re-used for any purpose...........same as if it was poisonous material)
And one for sand is full of well-meaning cautions which argue strongly for having the beaches closed and sand volleyball banned.........
[This message has been edited by Oso (edited 07-11-2003).]
I too was curious about the flammability danger of Ta. But I don't know enough to give advice concerning the safety of a kid working with it. I'm sure somebody on the board has expertise in refractory metals.
I imagine the tantalum in a capacitor is fully oxidised, as in tantalum dioxide. No fire hazard there.
Incidentally, If aluminum is powdered finely enough and kept in a vacuum, it will explode upon being thrown in the air as a dust.
[This message has been edited by Evan (edited 07-11-2003).]
If the tantalum were oxidised, it would not be conductive, and hence would not function.
The parts are polarized electrolytic parts, not made with some sort of tantalum-based ceramic.
Quite a few metal oxides are conductive, silver oxides and tin oxide for example. Tin oxide is also transparent and is used for the conductive traces on an LCD panel. It is also used for the anti-static coating on a CRT.
As it happens, in a tantalum capacitor the tantalum oxide is the dielectric. Newer tantalum capacitors will use tantalum pentoxide which has a much higher K value.
I have seen the tantalum caps burn during ICT test.
They aren't nearly as dramatic as an electrolytic cap inserted backwards though.
The tantalum caps that burned were a defective lot, and were installed correctly.
- You may not post replies
- You may not edit your posts
Forum Rules
