Results 1 to 6 of 6
Thread: New and improved engraving tool
    52N 122W Western Kanuckistan
    Default New and improved engraving tool
    I engraved a circuit board today and before starting I decided I needed a better engraving tool for the job, so I made one. This is a very easy tool to make and it works very well. It's designed to take 1/4" bits, in this case a HSS router engraving bit. There are no adjustments and changing the tool bit is a one second process. It is spring loaded and very repeatable.
    It has only one machined part, the main barrel. It is drilled out on the lathe to a few thousandths of an inch less than 1/4" and then reamed to 1/4". This is the critical part in this type of tool holder as the bit must not have any free play from side to side or it will distort the engraving as the lash is taken up each time it changes direction. The barrel must be of a non magnetic material such as brass or aluminum. The upper part of the barrel is turned to fit a convenient collet size, in this case 3/4" but it could be anything down to 1/2 or even slightly smaller. The top .5" of the bore is tapped 5/16 x 18 NC to fit a set screw. A spring is needed and almost anything that will fit freely inside a .25 hole will do, even a ball point pen spring.
    The key items in this design are a couple of small super magnets, in this case .312" in diameter. A .25" through hole is drilled in the lower barrel and it is then counterbored for a press fit of the magnets. The magnets should seat on a rim at the bottom of the counterbore so they cannot pass into the central bore. If a good solid press fit cannot be obtained then the magnets should be retained with locktite or similar. If there is any doubt as to the security of the magnets then an outside collar of brass or aluminum should be fitted to ensure the magnets do not fly loose in operation.
    Another feature of this tool holder is that there is no need for a drive pin or dog of any sort. The magnets are emplaced so that one presents a south pole face and the other a north pole face. In other words they should be attracting, not repelling. The tool bit is wiped across one of the magnets before loading and this is sufficient to magnetize the tool so that the magnets not only retain the tool but drive it as well.
    Apr 2006
    China, ME
    Nice work, Evan. Did somebody give you a new box O' magnets to play with recently?
    Todd
    Jun 2005
    Mapleton, IL
    Two questions....isn't that cutter double ended? If so, you have a spring wearing on the "other" end of the cutter? I guess it misses the critical point so maybe its no big deal.
    The other question relates to spring loading it.... Doesn't that make for a lack of real depth control? That is, if you move the cutter deeper, its under spring tension and will eventually dig in to the new depth, but starts cutting deeper potentially after the workpiece moves relative to the point?
    Paul
    Paul Carpenter
    Mapleton, IL
    Jul 2004
    Tarkio,Mo.
    OK so I'll ask.....picture please of the board.
    Gary Davison
    Nov 2005
    kewl!
    Very neat little drag engraver. What prompted the new design? Did the old lack precision in the bore?
    Would love to see the pc board. Even better a YouTube video of the engraver in action.
    Best,
    BW
    Depth is controlled by how far you push down on the cutter and how fast you are engraving. It's remarkably consistent as long as the cutter doesn't dwell in one spot. It eliminates problems with slight warpage in the material which is common with FR4 material. Because the cutter has a long travel slight differences don't make much change in the force applied.
    This is the board, it isn't finished and ended up being a test of the cutter. This board wasn't pre or post processed in any way, in particular there were absolutely no burrs to remove. The board is designed for isolation milling where the traces aren't delineated but instead islands for common connections are created. It's also intended for surface mount on the copper side.
    It isn't a drag engraver. When you magnetize the tool it becomes polarized to the magnets so that they prevent it from slipping when the tool is spinning. It takes very little to hold the tool from slipping as the torque multiplication from .250 to .005 is rather large.
