I have had a Lincoln Weldpac wire feed 155 for probably 5-6 years and it has worked fine, now it is acting up and seems to want to weld fine at times and at others it seems if running on a low setting to want to be way too hot!
I do not really understand just what is happening but something is not right at all? If I turn it off and re start then at times it will be fine?
Any ideas?
Thanks in advance.
