Even with a c clamp or other clamping or magnet, the easiest and cheapest is still hit it with a 4 or 41/2" flap or grinder disk to remove the rust. The other thing you have to consider is that each piece of steel you add will need a mating part cleaned for good contact. Its just a fact of life. Clean you clamp and the steel.
Glen
