can't seem to find it googling - anyone have a link that gives the dimensions for the ER collet standard, ER11 specifically??
edit; I should it its the closer/chuck that i'm most interested in
thanks!
thanks!
The collet chuck is fairly easy to work out from the collet spec once you know that the offset or eccentric "ring" inside the nut runs in the groove on the collet, the nut fits the short taper & the body the longer on,
http://shopswarf.orconhosting.net.nz/colletmill.html
Regards,
Nick
McGyver,
The cavity is 8 degrees per side and 11mm at the opening as you probably know. The nut is threaded M14x0.75 which I think is what you're looking for.
Jan
McGyver, Rego-Fix (ER collet original designers) have lots of information on their web site.
Here is a link to the ER chuck 'cavity' page, and there is more info avalable from the sidebar.
http://www.rego-fix.ch/eng/katalog/ti/ti_fs.htm
Peter
thanks for all the help!
