Results 1 to 10 of 19
Thread: Will battery acid freeze?
    Feb 2005
    Default Will battery acid freeze?
    I have a bottle of battery acid. It is NOT in a battery. If its left in the garage unheated and it gets to -20 F will it freeze?
    Aug 2003
    Nazareth, PA
    "battery acid" is for the most part sulfuric acid.
    http://wiki.answers.com/Q/What_is_th..._sulfuric_acid
    Depends on the concentration.
    100% = 3C
    93% = -32C
    78% = -38C
    65% = -64C
    aren't internet searches fun!!!!!!!
    andy b.
    Oroville, WA
    Battery acid concentration in a battery is around 33% so the freezing point, interpolated from the above table, is quite low. Don't know what it might be in a jar.
    Never add water to sulfuric acid!
    Sep 2006
    Big Prairie Mi.
    Don't know about the 'clean' never used acid itself, but do know that a discharged battery will freeze pretty easily, being fully charged seems to drop it's freezing point.
    Ken.
    Jun 2007
    North of of the fudge tourists
    Quote Originally Posted by dp
    Interpolated? Extrapolated? For sure about the water and acid comment. While searching for data on battery use I found this chart.
    I'm more used to lead, tin curves. Usually the temp/freezing curve looks like an U of sorts.
    Clutch
    Quote Originally Posted by kendall
    Ken.
    This is because a discharged battery contains little acid......
    "charging" involves driving the sulphur from the plates into the water as acid with an electric current, "discharging" is the process of combining the acid with the plate material while getting an electric current out.
    Jul 2007
    Seems that nobody actually answered your ask. If it is "plain old battery strength acid," it will NOT freeze at -20 F. Interestingly, a fully charged battery that is "cold soaked" to about -40F will not discharge at all. The battery itself is apparently not damaged and functions just fine when the temperature rises.
    Feb 2005
    Thanks guys and thanks Duffy!!
    Sep 2006
    DeWinton, Alberta, Canada.
    This I think, has all the info.
    http://www.cdtechno.com/custserv/pdf/7953.pdf
    Feb 2005
    THANKS RancherBill, So it appears that it would freeze at +28F . (note: the battery was "shorted" before the acid was removed)
