Hello
We have a LeBlond Regal 13C3 lathe that is a 196? model. Someone must have jammed the carriage during operation and broke something in the drive because it will not feed automatically now. The Feed Rod is turning but the carriage will not move when engaged. I see by looking underneath that the Feed Rod goes through a Pinion gear on the back of the carriage. I figure that maybe a key is broken inside the pinion. Do I need to remove the whole carriage by sliding it off the end of the machine, or is there an easier way to repair this ? Your expert opinion can probably save a whole lot of unnecessary work. Oh Yeah, My book shows that the Feed Rod is a splined rod with 6 grooves, but our machine has a smooth rod with a keyway cut the entire length. It also dosen't have the Safety clutch to prevent accidents from breaking something.
Thanks
The easiest way I have found to remove the apron is to first remove the lead screw. This is easily done by removing the support block at the tail stock end then pulling the lead screw out toward the tail stock. On my lathe the lead screw is held into a gearbox with a tapered pin, drive out the pin and pull out the lead. My machine is a sliding gap so the lead screw is driven by an intermediate gearbox, yours will be driven directly from the quick change box. After the lead is out you can support the apron and remove the top screws and the apron will be free to drop straight down off the pins in the carriage. I have found that a floor jack and a block of wood works great to support the apron. Be careful, the apron is quite heavy and unruly when supported on a floor jack.
