Results 1 to 6 of 6
Thread: Module gear`s Help
    Aug 2005
    shreveport La
    Post Module gear`s Help
    I can and know how to figure out diametral pitch gears. But Module I am lost.
    Looks like on the Katrina Lathe project I might have to make some Module gears.
    How do you figure out what module you have. Book said .( Module =divide circular pitch by 3.1416 ) But what is the circular pitch. Book said ( Circular pitch = multiply module by 3.1416 ) I do not have the module are the circular pitch how do I find them. All I have is out side diameter and number of teeth. I need to know the module to work this out. OK all you smart people lets have some answers . Bill needs his lathe fixed. This sounds like the chicken and the egg thing.
    Sep 2008
    Lane
    According to my text book (Technology of Machine Tools by Krar and Oswald)
    Module can be found by dividing the Outside Diameter by the Number of teeth +2
    M = OD/N+2
    Hope this helps
    Al
    Nottingham, England
    25.4 divided by DP
    Module is number of teeth plus 2 divided by OD in MILLIMETRES.
    DP is number of teeth plus 2 divided by OD in INCHES
    London, UK
    I never thought I'd get the chance to correct the Earl of Nottingham.
    John - you've quoted the MOD formula upside down.
    MOD = OD (in millimetres) divided by (number of teeth plus 2)
    Best get back to laying those flagstones !
    Richard
    Nottingham, England
    Quote Originally Posted by rohart
    Isn't Lane Australian ????
    Yes you are correct, well spotted, it's been a long day but gear related.
    Started off in the workshop at 2:30 today with a 15" length of 30mm steel, drilled it from both ends, reamed it in stages and parted off 30 slices 3/8" thick.
    Transferred these in batches of 10 on a mandrel to the hobber and cut 20 teeth on the stick of modified form to give them more strength. Broached a 1/8" keyway in them all and locked up at 5:30 for my tea, not bad for 3 hours work.
    Aug 2005
    shreveport La
    Smile
    Isn't Lane Australian ???? H-ll No Good old US of A . A souther boy to be exact. Thanks all I think get it now .
