I'm a rank amateur, but I have taken a semester-long welding class, and this was my experience with welding cast iron. It might explain why you hear both answers about whether cast iron can be welded
One of the guys in our class brought in a clincher breaker, which had been sitting at the botton of a coal forge for 50 years. That's probably a worst-case scenario, but the instructor asked me how I would weld it. By that point, I was getting pretty good at TIG, so I pickup up an nickel rod, sharpened a 1/8" electrode, and went at it. Instantly, the electrode popped from all the crap in the cast iron. I tried this three times before I realized the instructor was grinning.
The "trick"was to use a stick welder with nickel rod, but I've got to tell you, it looked like sh!t when I was done: I'd grind out the cracks, pre-heat the casting, skip weld in the cracks, and then repeat. But you'd get little fine hairline cracks all around the nickel bead. So I'd grind some more, fill it in with more nickel, etc, etc. When it got to the point where I thought the clinker was solid nickel, I gave up, but the welding instructor said that's about as good as it was going to get.
The welds held, but it sure didn't look pretty, and I sure wouldn't want to use it on a piece that had any load on it (like a piece from a machine tool).
I found that brazing cast iron, by contrast, is way easier. The bronze braze is flexible/malleable, so it doesn't pull the cast iron apart.
This is the cast iron nose piece of an old drill press that I MIG brazed with Aluminum Bronze. The piece is a heck of a lot cleaner than the clinker breaker, but it's not virgin either:
Never ever attempt to weld cast iron with steel filler, it may seem to hold ok but the transition area between the weld bead and the base metal will be EXTREMELY hard and brittle and have very little strength. Welding cast iron with duel-shield steel wire is a real no-no! The big problem here is that once the base metal is contaminated with the steel it will have to all be removed (the contaminated area) before it can be welded with the proper material because that area will be completely destroyed from a strength standpoint. NEVER attempt to weld cast iron with steel filler!!!
