I just made several 2" diameter inserts on the lathe and had no problem. I used a sever rake with moderately radiusd cutting edge and it gave me a smooth shiney factory look surface.
I cut mine out in squares, drew an X across them, drilled them out. Then stuck a bolt in the 3jaw slid the square over it and tightened a nut down over it and turned it.
