I don't see anything different with Bob's cross slide either. The 6" was much smaller.
The 12" Craftsman lathe was basically the 10" Atlas lathe raised one inch. The headstock and tailstock castings were raised at the base. The apron and cross slide were not changed, the additional inch of height was achieved by raising the height of the compound casting.
The power cross feed was available on some lathes and not others, as was the tapered or babbit bearing headstock.
Looking at the picture in post #8, the cross slide looked short. It's obvious now that it has four gibs. The compound is the same as mine. It overhangs when centered. I usually run with the front (toward center line) and center gib on the V. The locking screw was moved to the center on the compound. (Shows front in pic.) I moved it to the center so it's a more positive lock no matter where the compound is located.
