I Recently worked on a couple of I/R B.F.P.'s with these superbolt nuts holding the discharge head on. Thier made up of 24 3/4-16 hardened jack bolts that you torque up to 360 ft/lbs to strech the main stud. These pumps had 12 studs each so you get to torq. 288 3/4" bolts till all are stretched even. We had to cut and or beat 6 or 7 to get them off main studs for some reason. It was a very time consuming process to use these over a heated stud growth or hytorq. nut method. We also used an air powered hy-torq torqe gun to twist the jakbolts off/on as needed, its a pretty slick gun too. They claim ease of use with only small handtools needed for these but I'll take the old calrod have a cigerett and wait stretch with castelated nuts anyday. Just wondered if anyone else has run into these superbolts and were
Thanks, John
