Do not have a 4th axis on the mill, any ideas on how you might go about machining the helix?
Ken
It is about 1" in length and 7/8" in diameter.
Ken
That is not just a simple helix, it is a cylindrical cam. Looks like a job for a pantograph or CNC to me! Gary P. Hansen
Break Cam Path up into as many x or y movements needed for application (say 1 x or y move per Degree of rotation), and cut Cam path Manually, one small bit at a time... Smooth out with file if needed...
Old School...
New School, have someone CNC it for you...
First question is what are the tolerances?
Also, it doesn't look like a helix. What is the side view?
If you can get away with a helix then mount the job up on a mandrel and on an extension to the mandrel weld two washers, each with 4 tapped holes in and a space about 3/4" between the washers. Weld the washers so the 4 holes are equally offset in each before you weld the last washer on drop a large washer with a sloppy bore between.
Now by using 8 push pull screws you can make this washer follow a helix to the extent of the spacing.
Set a follower up from the toolpost or saddle, whatever is most convenient and run at low speed.
The wobble washer will pull and push the saddle and you can apply a cut.
That's how we used to machine the helix groove in Pilgrim oil pumps.
I can do a sketch if needed.
Gary and Bguns, thanks for the input, was hoping to come up with a solution using the tools on hand, have a CNC mill but no CNC controlled 4th, breaking it up into a bunch of coordinates was a method I was not wanting to do, would work but very slow and prone to mistakes.
John, let me read your suggestion a few more time to see if I can visualize what you are doing, if not then a sketch woul be helpful.
Evan,
Tolerances show +/- .005 , pretty loose.
Side View:
If you can mount a suitable end mill on a powered horizontal spindle on the table, put the part on a mandrel in the CNC spindle. You use the X and Z axis to machine the part to whatever profile you want. This assumes you have servo control of the motor spindle - perhaps not a good assumption on on second thought (hence the edit).
- Bart
Bart Smaalders
http://smaalders.net/barts
I have an extra one of those, made on a cnc mill. For the Rgg gun right?
Daveo,
A close cousin, for the D&E version.
Ken
I gave up on mine, had a guy make a couple up. Very tough to make
