Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Why are lathe ways shaped the way they are?
    Feb 2008
    Prince Edward Island Canada
    Default Why are lathe ways shaped the way they are?
    This is the shape of my lathe ways:
    Seems to be a pretty common shape.
    Seems pretty complicated.
    Why?
    Why so many surfaces? Why is one side higher than the other? Why is one side larger than the other. Why is there 2 seperate sides at all, Why not just have one flat top and 2 perpendicular sides?
    tony ennis Guest
    Wow, what a can of worms you've opened.
    *makes some popcorn and gets comfortable*
    Its like bring up comparisons in boat hulls
    Sep 2006
    Southwestern Ontario, Canada
    There are many way configurations. Flat, inverted vee or a combination of both and don't forget the round bed ways or the bar beds like the Barker, Unimat and the triangular bed lathes.
    People have been arguing the merits of bed configuration for at least 150 years, each type has its advantages and disadvantages. Inverted vee type tolerate wear better, holding there accuracy but some people think flat beds are more sturdy and less prone to having the saddles lift under heavy loading. Bar beds like the Drummond Round bed were used to make lathes cheaper so amateurs like us could afford a lathe but they had trade offs in use.
    It's apples and oranges.
    Check out books like "Lathe Design and Construction and Operation", Lindsay Press sells it but you mite be able to download it off of the Internet archive or google books for free. It's old but still relevant on this subject.
    Nottingham, England
    A lot of it has to do with hereditary design, the country of origin and the price of kippers.....
    Feb 2008
    On the shape that I have shown, how many of the surfaces are actually in contact with the carrage? They can't all be... can they?
    Oct 2004
    Prestatyn, North-Wales
    One inverted v is for the carriage the other is for the tailstock.
    They are great until they wear ...then you have to be a master craftsman to get them right again ..
    The all flat ways Machines are much simpler and could be put right with the minimum of specialised tooling when they wear out.
    all the best.markj
    Topeka, KS
    Usually on the style in your picture, the carriage uses one vee and one flat and the tailstock uses the others.
    Jon Bohlander
    My PM Blog
    Mar 2008
    Barrie, Ontario, Canada
    And the machined underside towards the center is where the carriage lock rides against.
    Jun 2006
    Austin, Texas
    Quote Originally Posted by aboard_epsilon
    Oh, I thought it was because British engineers hadn't discovered prismatic ways yet?
