Results 1 to 10 of 13
Thread: 6 Inch PVC PIPE
    Sep 2004
    Default 6 Inch PVC PIPE
    Question when boring the inside of this pipe how do you keep the surface finish appearing transparent or clear so to speak??? I have these 6 inch pvc diameter pipe pieces to machine, they are oval a bit ,even at 89 dollars a foot .? Now i plan on using a piece of aluminumn and turning it down (the aluminumn) to fit inside the Unmachined inside 6 inch pipe diameter THEN i am going to machine the other Half of this aluminumn fixture down to the finish inside PVC Pipe Diameter diameter minus a .001 or .002 thou. Then jam the machined end of the pvc onto the other end of the fixture and bore that half ,flip part and also switch fixture to the bored diameter and bore the other side .Whew finger typing cramp. I have 2 pieces to make and they are 6.300 inches long. Thanx Guys madman
    52N 122W Western Kanuckistan
    What color is the plastic Mike?
    Sep 2004
    Default Hello Evan
    It is clear or tranparent plastic pvc pipe. I sure get interesting work LOL thanx Mike
    Are you certain it is PVC and not some other plastic?
    Sep 2004
    Default Yes PVC
    PVC PIPE EVAN thats what it is. Thanx Mike
    Transparent PVC will not cut to a transparent surface. You can get fairly close with a very sharp high rake tool that has a large radius but if it needs to be completely transparent then it will have to be polished after machining.
    Jun 2008
    You could try Solvent polishing after machining.
    Regards Ian.
    Sep 2004
    Default What a PAIN in tha A..!!!!
    Well i got some 8 inch diameter OD and 6 inch ID DOM Pipe and bored it out to hold my PVC Pipe. Then machined (Turned the Outside) NOW i am going to drill and taop a Pile of 3/8 inch tapped holes all over the outside and use set screws to hols (squish ??) the pvc pipe ropund ?? What a Pain I called the Pipe company but Noone knows why there pipe is **** quality out of round?? LOL Oh well
    Clear? Bummer.
    I was hoping someone was going to be doing something with purple PVC pipe.
    A truckload of the stuff is a real eyecatcher.
    Roger
    Western New York U.$.A
    A friend of mine had good luck using regular household vegetable oil when drilling/machining acrylic plastic. You might give that a try. They were making experimental hydraulic test blocks and wanted to see what was going on through the plastic.
