Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Cannon build question
    Jan 2009
    Default Boom
    Quote Originally Posted by j king
    I started to build a cannon,I wanted to use a reloaded 12 guage shell without shot or any projectile.A buddy told me that that is illegal to build.Is this true?
    I was making the barrel bore larger than the chamber.Just wanted a quick and easy way to set it off.
    Do you just want it to make noise? If so, why not have it use only a 209 primer? The smokeless powder in shotgun shells will not burn without pressure so the unburned powder will just fly out the barrel. In order to make a bigger BOOM you may have to try blackpowder which will BOOM without pressure. I like the primer only idea. You could turn it down and tune it to make the proper pitched BOOM, whatever that might be.
    here is my newest cannon. Lapan's foundry in Glen's Falls NY, 1970's or so. 2.25 bore..perfect for concrete filled tomato paste can launching
