Results 1 to 5 of 5
Thread: south bend lathe questions
    Default south bend lathe questions
    Anybody know if it is possible to replace a threaded spindle on an older machine, like a 9 or a 16 with a cam lock? Does anyone know if a single tumbler gearbox can be replaced with a double tumbler and where one might be found? Does anyone have a good idea of how to mount a horizontal drive above or below the lathe to take up less space? Thanks
    Jul 2005
    Bloomington, IN
    Sounds like you just need to upsize to a bigger/better lathe
    Clinton, WA
    Some of the 10" SB lathes had a D1-4 cam lock spindle,
    http://www.southbendlathe.com/GS26LT.htm
    Mark Hockett
    Jun 2006
    NE Corner of NC
    Default Single Tumbler vice Double Tumbler Box
    The gearing between the spindle and the tumbler box is different. The gearing used by the single tumbet box is NOT the same as the gearing for the double tumbler box. Changing between a single and double tumbler box is not a trivial process. A lot more has to be changed that just the tumbler boxes, even if they would fit identically!
    Bill
    Thanks for the information.
