I always thought it would be neat to have the splitting unit dangling from a chain so you could have on something like your bobcat and swing it in an arc and then lower to the log and split the logs without moving them. The operator would stand beside the log and control the up/down motion of the lift and the in/out of the ram with a hand control. No lifting!
You might build like some I"ve seen where the actual ram unit is on a hinge that tilts to vertical or normal horizontal.
