Originally Posted by
HighWall
Traditionally, no adhesives are used. The idea is for the patch to detach shortly after the projectile leaves the muzzle. If the patch is retained, it's detrimental to accuracy.
The above is correct, although I have had people tell me they've used masking tape and address labels with success. I've never bothered to try it. Very possibly as a traditional paper patch is scored/cut by the lands and then blown to shreds at the muzzle by the closely following high pressure gas, the adhesive isn't an issue? Maybe their definition of success and mine differ :-) .As I said, I've not tried them.
Basically the paper is wetted well, and is then stretched as it is rolled on the slug. The paper at the base is rolled under the base, the base of thepatched slug is pressed tightly down onto a hard smooth surface and then given a twist, then allowed to dry. Alternately some will twist the paper over the base into a 'tail'. When dry it's clipped off. As the paper is stretched when it's rolled on, when drying it shrinks and when dry will grip the bullet tenaciously.
The ability of the paper to be wetted and still retain the strength to be stretched as it's rolled on, is the criteria for a paper's suitability. I had a friend who used some 4 color insert advertising paper to patch some bullets. In addition he was using a bit of toilet paper over his powder charge and a card wad under the slug. Upon shooting he had a absolute cloud of paper shreds floating around :-)
If you have a problem getting the paper to stick to itself, it's possible it isn't wet enough. However you can also add just a small bit of egg white to the water as an aid to 'stickiness'. Via sizing of the slug before patching, after patching, and the thickness of the paper you can achieve a very wide range of OD's. Remember, the thicker the paper to start with, the more you'll lose when it shrinks as it dries. You also do not have to have a bullet designed for patching to be successfully patched.
These 577-450's use a 405gr grease groove bullet as cast @.460" and then get 2 wraps of 24# bond for a dry OD of .472". If you do not have a slug in mind for your Mauser, either the Lyman or RCBS mould for the .43 Spanish will work well. They drop from the mould at about (.439" nominal) .440" or so depending upon your alloy and will weigh about 370 grs. Two wraps of 9# paper will give you a dry OD of .447" for your .446" groove, if the chamber will accept this OD. Early cartridge rifles can have issues in this regard, but you may already be aware of these. Regardless, you can easily size the patched slug down a thousandth if need be.
One other thing in patching is that the leading edge of the patch cannot be damaged if feeding from a magazine or in chambering. Accuracy can suffer. You can barely see in the photo that the bullet is engraved as is the patch. The patch is being pressed down into the slug and not being pushed back or wrinkled up. You might have to patch over the ogive or into a crimp or lube groove.
Rick
Son of the silver stream ..... Bullet caster.
