Want to mill a flat surface using a small mill (600 watt or 3/4 hp DC motor). Mfrs claimed capacity is 2-1/2 in face mill.
Trying to decide between a single point flycutter http://busybeetools.ca/cgi-bin/picture10?NTITEM=B090 and this 3-insert carbide http://busybeetools.ca/cgi-bin/pictu...TITEM=B2136MT3.
The carbide includes the insert bits (3) but the single point uses standard (non-supplied) tool bits.
I'm thinking "standard tool bits" means lathe tool bits. What shape would I have to grind on the bit?
Can I expect a smoother finish with the multi-bit carbide?
If the single point fly cutter and 3-point carbide are set to the same diameter of cut (ie., 2 inches) do I need to adjust the speed/feed/depth of cut of the carbide vs the fly cutter (since, I am thinking, the carbide has 3 cutters vs one)?
Any other pointers appreciated.
Thanks.
