Brain fade
I thought I started a thread regarding posting pictures. It never showed up or I can't find it. So lets try again. Some threads have pictures that open when you open the thread and others require you to open a photobucket link. So how do I get it to include my photos?
Thanks in advance
Pete
If you want the image to be included without any links just copy and past the address propertys. Here's an example. [img]link here [/img] The link would depend where you have the image hosted, just copy the location link by right clicking and properties. Copy the location and paste between the brackets. Hope that makes sense.
Check out my work
Here
Clinton
The way I do it is in my photo album on Photobucket I high light the img line under the photo and hold ctrl key and press C key. Then I go to the site and hit post and then use ctrl/V and the img link shows in the box. Then I add text.
- You may not post replies
- You may not edit your posts
Forum Rules
