dore-westbury mill
Hi all, I have been using a Dore -Westbury mill (built from kit) ocassionally over the years and I decided to clean and lube the gear head. There was no wear and tear showing so fresh lube was all that was necessary. Trouble is I can not get the gears to remesh and sit together. Nothing was changed so is there a method of reassembly?
Thanks in advance for any info. Cooter
OK all is well with Dore-Westbury mill. Just a matter of lining up or timing the gear teeth in the reduction set. Now back to work! Cooter
- You may not post replies
- You may not edit your posts
Forum Rules
