Results 1 to 5 of 5
Thread: Speed, Feed Depth of cut
    Las Vegas
    Default Speed, Feed Depth of cut
    Somewhere in my foggy old brain I remember increase feed rate first, depth of cut second and speed last. Is my brain working or is it reversed? The formula not my brain.
    thanks
    ed
    Taylorsville Ky
    I don't use an iron clad method like that but I just go with a gut feeling depending on the material and what your trying to achieve.
    With hard material you don't want to increase the speed to much and more DOC may be the first try. Then feed rate.
    Hot roll and cold roll I set the rpm and then experiment with DOC and feed.
    It really depends on what is happening and what your trying to get.
    Las Vegas
    Thanks, that is pretty much the way I do it. I had a lot of crs to hog out today and decided to keep the speed constant and work w/ doc & feed rate.
    Taylorsville Ky
    Many times you can improve you finish cut by uping the rpm and maybe slowing the feed and a very small radius on the cutter tip. I usually end up with a file and/or emery cloth to get the finish I want.
    Mar 2009
    Default RPM Calculation
    The formula is...........
    (4) X (Cutting Speed) divided by the Diameter of the work.
    Cutting Speeds as follow...
    Aluminum 200
    Mild Steel 100
    Tool Steel 50
    These are High Speed Steel Tooling numbers. If using Carbide multiply by 3.
    Mill or Lathe or whatever. Softer = Deeper ,and Harder = Shallower. Bigger = Slower, and Smaller = Faster.
