Well sense you did not say how long a barrel it is I will assume it to be 10". Never did one, but if I were to try I think I would use an action truing fixture and set it up the same as an action.
http://www.gtrtooling.com/prod05.htm The fixture is just a tube with 4 bolts front and rear to align the bore, a mandrel, or range rod, that just fits the bore with around 2 inches left to stick out the muzzle, 2 indicators one close to the muzzle and the other at the end of the mandrel and adjust till there is as little run out as possible on both indicators. Take light cuts and crown. It will take longer to set up than it will to cut the crown.
