I'm looking to turn the part in the picture below, but I'm not entirely sure how to make the machine do the the 180* radius. I've done plenty of 90* ones. Do I need to do it in two lines of code, one for the first 90 and one for the second? Or do I just give it the Z movement and the radius and hope it will fill in the X movement? It's a Haas lathe (Fanuc controls) and the tool uses .250" diameter round inserts. I was thinking I would cut a series of progressively deeper radii until I reach my full depth (OD is 2" and diameter at the bottom of the radius will be 1.5", material is 1018).
Thanks a lot!
Stuart
