That's sure lucky, Ron. Otherwise, you could have ended up with that screw imbedded in a body part.
The trouble with on-line forums is that you get information on what worked....but often those solutions depended on a lot of luck. This is a great example....that same screw could have become a projectile.
Pressure vessel failures can be pretty catastrophic. It's the very reason that they have to be hydro-tested from time to time in commercial environments. This is not an exercise that is done for the fun of it.
Want a new air compressor tank (small)? Go to www.surpluscenter.com and search on air tank. There are several small ones there with wheels, handles and mounting points for the motor and compressor.
Paul
Paul Carpenter
Mapleton, IL
