Results 1 to 3 of 3
Thread: machining technique for cylinder - revisited
    Jul 2001
    Post machining technique for cylinder - revisited
    Original post at end...
    I ended up centering in 4-jaw, turning 1/2 length to 1 1/2" OD, reversing in chuck and finishing the length to 1 1/2". I then drilled and bored to 1.000". To finish the OD, I made a mandrel ( 10" length between centers) ala Phil Duclos's "stub mandrel" technique and mounted my stock near the tailstock. Ended up with a wall thickness of +/- .0005.
    posted 08-27-2003 08:00 PM
    I need to make a tube of cast iron..2 7/8" long, 1.000" ID, 1.3755" OD.
    Problem is,, I didn't think it through when I bought the material; I have a 3" long piece of cast iron.
    If I had a longer piece I could chuck it up and bore the ID and turn the OD with the same setup.
    OOPS!!
    Any suggestions to salvage this or should I just get another, longer piece of stock??? I have an 8" 4-jaw chuck as well as other "goodies" however, I'm using a 12" swing, 3in1 lathe/mill.
    Mar 2003
    Sounds like you did a good job there,rmatel!
    Congratulations,Robert.
    Deep in the Heart of Texas!
    Dang! .0005 is good enough for the drag strip. Lets go racing!
    "Big Factory" engines don't come that close. Great Job!
