Results 1 to 10 of 34
Thread: What does a 'Lathe Dog' do?
    Jan 2009
    Default What does a 'Lathe Dog' do?
    For the life of me I can't understand what it does. I've read countless threads, articles, looked at pictures, sketches, etc. and I can't figure out what it does differently than a 4 jaw chuck.
    Apr 2006
    citrus heights, ca
    A lathe dog is used to drive the work that is between centers. If You had a shaft between centers without the dog it would be like leaving the key out of a keyway.
    Steve
    Mar 2003
    4-jaw?
    A lathe dog is a device used to drive a workpiece when turning between centers. And that means, instead of holding the shaft in a chuck, you have a center in both the headstock and tailstock.
    The headstock end is of course a "dead" center, while the tailstock can be either a live center or dead.
    The "dog" clamps to the shaft, and the leg of the dog engages a slot or hole in either a faceplate or "drive plate".
    In this photo, the machinist has clamped a center in the chuck, and the leg of the lathe dog is being driven by one of the chuck jaws.
    The technique predates chucks, and so tended to fall out of favor once 3-jaw and 4-jaws came on the scene. But turning between centers still has one solid benefit, in that it's very easy to remove the workpiece, for fitting, measuring or testing, and then put it back in the lathe very close to, if not spot-on, the original zero.
    Doc.
    Beaverton, OR
    Yep, like Doc said. Turning between centers is one of the most accurate ways to turn a part, especially things like a shaft that need to be flipped. Traditionally they are used with a dog drive plate as seen here on my monarch.
    Jun 2008
    Mine used to lay across the entrance to my workshop to stop visitors "Surprising" me while machining.
    Regards Ian.
    May 2009
    Quote Originally Posted by Circlip
    Regards Ian.
    Yessir, and if you're not careful he'll take a bite out of you wherever he is.
    Jan 2009
    Thanks for the replies, but I'm still confused how it differs from a chuck. I guess I can't figure out why I would use it versus a chuck.
    Apr 2007
    Fairport NY
    Well...
    I take a shaft and I bore two holes in it. Then I put a center in the head of the lathe and in the tailstock.
    Now I suspend the part between these two parts and engage it with the dog. The dog locks onto the part and transfers the spin from the faceplate to the part.
    On paper, I can disengage the dog, take my part out and flip it around (end for end) and still have it keep the same location in the machine.
    You really can't do that with a jaw-chuck unless you are very very very good.
    Another advantage is you can turn long irregular parts that won't fit in the jaws.
    That said... Twice I've used this method in all the hours I've logged on the lathe. I'm more of a collet-chuck/turret-lathe/mass-production dood than a turner of epic parts.
    Plastic Operators Dot Com
    Jan 2009
    Southern WI
    In today's machine shops, lathe dogs have NO place. Nobody cares about T.I.R about a given centerline. It simply is not cost effective, (They Think). We live in a world of Throw-away goods, where the Land-fills ARE a money making proposition. I just wonder what our children are going to do after we have used up Everything.
    If you want to make something precision, you use centers and a drive dog, when multiple set-ups are required or when repairing / reworking parts.
    May 2009
    "I guess I can't figure out why I would use it versus a chuck. "
    If you aren't a well equipped HSM, say you wanted to turn taper between centers. You don't have a taper attachment. The dog drives the work from a center aligned with tailstock offset to required taper. Can't do that with a chuck.
    For fussier accuracy (TIR), dogs don't have jaw domination like three jaw chucks.
