I need to cut some 100mm holes in some 30mm thick foam.The foam is basically the same as used in upholstery and is too soft to hold by any normal means.
Only thing I can think of at the moment is to turn up something like a cookie cutter and press and twist that through,but any other ideas would be appreciated.
Allan
