Results 1 to 5 of 5
Thread: j28
    Default j28
    hi Guys just got a Victor J28 torch and regulator set at a swapmeet, changed the fittings over to suit australian gas cylinders. any recomendations pressure setings (gauges are in PSI) the tip seems to be size 2 these are quite uncomon here in OZ so any info will help
    Thanks
    May 2009
    If you're welding, use equal pressure, pretty much. I don't find that written in stone but a good departure point.
    If you have the cutting attachment, about 8-10PSI acetylene and 20 PSI oxy will cut 1/4" dead clean with a tip in fettle, no slag. For 1" steel the oxy will only need to be 40-50 PSI, acetylene stays 8-10.
    Sorry, no metric conversions, have had the two pints.
    What's the orifice on the #2?
    You can get a cutting attachment for this????? its tiny
    tip size, a 1.1mm drill bit is loose and 1.2mm wont fit so i think its 3/64ths
    i only plan on using it for nickel bronze
    from what i found on the web making bike frames seems a popular use for these
    thanks for the info
    May 2009
    "You can get a cutting attachment for this????? "
    I'm not sure, but wouldn't be surprised. I have a tiny Harris aircraft torch that cuts.
    Albireo Guest
    This link may be useful. Be sure to read it because it contains
    good safety points. Mind the maxium gas flow per size of cylinders. It
    seems that bit of knowledge is not wide spread.
    HTML Code:
    http://www.thermadyne.com/IM_Uploads/DocLib_2879_56-0114%20guide_lo.pdf
