I have an older Slavia 630 break barrel air rifle in .177 caliber. For the Canadian market this gun was derated to less 500fps muzzle velocity. What I would like to know is if the muzzle velocity can be increased by sourcing a higher rate spring (if so where?) or machining a spring shim to increase the preload. Also, much the same question for a Beeman air rifle. If I have a Canadian market version with the lower muzzle velocity is there a means to increase it?
Mr. Mike.
