Originally Posted by
Carld
Hmm, I was a Briggs dealer in the '70's too. I would check the comp. first and does it have oil and does the engine turn over easy without the plug.
Have you tried squirting gas in the intake while it is stumbling along? Have you checked the ignition, I think all of them are electronic now.
Over heating is what usually causes the valve seats to get loose. Usually when that happens the engine makes all kinds of noise just before it locks up though, especially if it's an overhead valve.
Yes to oil, pulls just like it did before, no change, it starts haven't pulled the plug yet. It slows up more with spray into the intake.
Shouldn't have had an over heating problem as it hasn't had plugged vanes or anything to impede the air flow to cause over heating. Had it running for about 40 minutes off and on after it started acting up.
Glen
