Results 1 to 10 of 13
Thread: Short 9 mm brass?
    Feb 2006
    Default Short 9 mm brass?
    Although I have reloaded multiple other calibers I have not reloaded 9mm Luger.I acquired some 9mm used brass in good condition stamped 9mm Luger but all measures.741 to .744 in length.Several books including Lyman,Dunlap etc use the figure of .752 to .754 and trim to.751(Lyman).Dunlap lists max chamber as .758.This brass would seem to create too much headspace unless the extractor holds the round securely when fired?I'm confused.
    Toledo, Ohio
    A quick check of a couple of reloading manuals agrees with the 0.754" dimension.
    It sounds like someone slipped a digit with the case trimmer. I don't think excess headspace will create a danger as much as it could result in reliability problems, causing a weak primer strike and potential extraction problems.
    If you purchased the brass, I would recommend returning it as it is not in spec.
    Palmer Alaska
    Default Having shot and reloaded Thousands of Rounds of 9mm..
    I don't know where SAAMI came up with that long .754 figure..
    Have to check the Euro version of SAAMI, CIP I think..
    Most European 9mm Ammo is well under .750 Brand new....
    S&B is ~.746
    PMP ~.744
    Canadian MKI Ball ~ .747
    Have a box of US Made UMC, it is around .752
    Have had no Problems with light primer strikes in Glocks, C96, Luger,
    Open Bolt Stens, UZIs, Macs.... MP5s etc...
    Feb 2006
    Will load some and try in P38 wearing eye protection etc.Thanks.
    Default Eye Protection
    Quote Originally Posted by Sophiedoc
    You should ALWAYS WEAR EYE PROTECTION when shooting!!!!!!!!!!!
    Do you thing anybody plans for a gun to malfunction or explode?
    Oct 2007
    Demokratik Republik of Washington
    Default be careful
    9mm is very susceptible to pressure. If the cases are short, it will drive pressure way up.
    If it were I, I would keep OAL to published data and load at minimum. But that is just me.
    Toledo, Ohio
    A short case can result in a compressed load and higher pressures, so care should be taken.
    If I remember correctly, European 9mm's are loaded at higher pressures, and the case length could contribute to that. The Luger requires quite a bit of pressure to operate and I seem to recall that some US ammo is too wimpy to for some to function reliably.
    Palmer Alaska
    Default Short brass WILL NOT DRIVE UP PRESSURE
    Seating bullets too deep in any 9mm/or other Brass can/will drive up pressure.
    Case length has nothing to do with Pressure. A slightly short case holds just as much with Bullet seated at same overall length as a longer case.
    Bullet seating depth can be critical on small capacity cases like the 9mm..
    Seating to recommended overall length will help minimise any chance of seating bullet too deep.
    As I stated before, the 9mm was an Import in the US and the US standards do not match Euro standards..
    Some of my older reloading manuals, skip the 9mm Para, even though guns were available ...
    Toledo, Ohio
    True, if you seat to the proper overall length, but it could be problematical if seating to the cannelure in the bullet. As with reloading any cartridge, all aspects should be checked & double checked, especially when working with maximum or near maximum loads.
    Palmer Alaska
    Default Taper crimp cartridge here...
    Roll Crimping into Cannelure will make things worse headspace/pressure wise.
    Taper crimp does not depend on Cannelure to secure Bullet. If Bullet has a Cannelure and is being used for a Taper crimp Cartridge ignore it...
    I really have loaded thousands of 9 mm..
    http://www.redding-reloading.com/pages/crimpdies.html
    Roll Crimping is NOT RECOMMENDED for 9mm, .45 Auto, .380 etc, Or any Cartridge that headspaces on mouth of case.......
    edit:
    There are always exceptions, and in this case, if loading for a Moon Clip type Revolver, a roll crimp into cannelure may be used.... Provided Overall length for that bullet/load is appropriate...
